Configures the weight for the peer group and all the neighbors of the peer group.
| peer-group-name | Specifies a peer group. |
| weight | Specifies a BGP peer group weight. Range is 0 to 65,535. |
N/A.
higher weight
higher local preference
shortest length (shortest AS path)
lowest origin code
lowest MED
route from external peer
lowest cost to Next Hop
lowest routerID
This command applies to the current VR or VRF context.
The following command configures the weight for the peer group outer and its neighbors:
configure bgp peer-group outer weight 5
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
